AD Authentication: Invalid DN syntax
Fabio_Dangelo
Fabio_Dangelo Posts: 21 image  Freshman Member
edited April 2024 in USG FLEX H Series
Hello.
Just update to 1.20 firmware to enable AD authentication.
The firewall FLEX500H is allready joined to AD and I can see it as Computer in Active Directory users and computers.
When I try to test the configuration I get the error "Invalid DN syntax".
What's wrong?
thank you
  • Fabio_Dangelo
    Solved!
    You have to be shure that user's distinguishedName is shorter than 63 char.
    If not it will fails.
    You can check user's distinguishedName in user advanced attributes in Active Directory User And Computer enabling "Advanced Features".
«1
  • Fabio_Dangelo
    any advise?
  • Zyxel_James
    Zyxel_James Posts: 809 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 100 Answers
    Please check on Advanced Settings, I suspect that you input the wrong information to Group Membership Attribute or something else.
  • Fabio_Dangelo
    this?
    I left the default values
  • YanShadowGT
    YanShadowGT Posts: 22 image  Freshman Member
    I have the same problem leaving the default values in advanced, the AD I want to connect to is Windows 2019
  • Fabio_Dangelo
    mine is 2016.
    I think the problem is this firewall (too young), not server OS.
    Let's see if ZyXEL can fix it.
  • Fabio_Dangelo
    Solved!
  • YanShadowGT
    It doesn't work for me, user's distinguishedName is shorter than 63 char and same error Invalid DN syntax
  • Fabio_Dangelo
    Test is the user account with administration rights used to join the domain and used to query the DC?
    Did you added the required DNS forward rule too?
  • YanShadowGT
    Thank you for your prompt help, I found the problem, it must be made clear that it only works in the Domain Users folder, if the user is in another folder it stops working.
    Everything working correctly!!!
  • fschenckel
    fschenckel Posts: 3 image  Freshman Member
    First Comment Sixth Anniversary
    I get exactly the same error (Invalid DN syntax). The domain is correctly joined, but all user tested are failing !
    We have users organised in several OUs, so the limit with 63 chars may be over.
    But hey, what's this for a limit ?? I'm coming from a VPN 100 and wanted the Flex 200H the replace it, but what a mess, these are absolutly not compatible, need to reconfigure all manually, and many functions are missing !!
    This seems an unfinished product to me. Can't understand ! I'm thinking about returning it…
    ⇒ Did you added the required DNS forward rule too?
    What means exactly this, could oit be related ?
    I hope someone can help !
    Thanks !
