How to configure IKEv2 VPN beštween Samsung Android and USG 60?
try here
https://support.zyxel.eu/hc/en-us/articles/8805317185298-IKEv2-VPN-with-Pre-Shared-key-on-Mobile-Devices-Instead-of-L2TP
I tried that one but it does not seem to work on Samsung device with Android 13. I found on the internet several people reporting the same problem but no one who has found a workable solution.
it starts to "talk" but the only result is line 60 below.0 -
Have no problem here with Android 12 and IKEv2
post your settings
set local policy to 0.0.0.0
Phase 2 PFS to DH2
Phase 1 key group may need to be higher
Encryption to AES128
check logs if Phase 1 show done
Thanks a lot for your help but doesn't work.
I adjusted config per your recommendation. But with DH14, DH19 and DH20 gateway gets disconnected. Other values return proposal mismatch.
try a simple Pre-shared key
on phone is IPsec identifier 0.0.0.0
Tried both already to no avail.
So your phone is by 4G/5G to your USG60?
keep trying till you see Phase 1 done
Sorry for being picky. It's a "pure IPSec" connection or an L2TP/IPsec connection between samsun phone and USG60? (which by the way is out of support but whatever…)
- 415 Beta Program
- 2.5K Nebula
- 152 Nebula Ideas
- 101 Nebula Status and Incidents
- 5.8K Security
- 296 USG FLEX H Series
- 281 Security Ideas
- 1.5K Switch
- 77 Switch Ideas
- 1.1K Wireless
- 42 Wireless Ideas
- 6.5K Consumer Product
- 254 Service & License
- 396 News and Release
- 85 Security Advisories
- 29 Education Center
- 3.6K FAQ
- 76 Security Highlight
