How to configure IKEv2 VPN beštween Samsung Android and USG 60?
emika56
emika56 Posts: 6
Is there any guide/white paper/config sample how to configure IKEv2 VPN with pre-shared key between Android 13 on Samsung device (phone/tablet) and USG firewall (USG 60/USG 210) running 4.73 firmware?
«1
    PeterUK Posts: 3,753  Guru Member
    edited May 2024
    try here
    https://support.zyxel.eu/hc/en-us/articles/8805317185298-IKEv2-VPN-with-Pre-Shared-key-on-Mobile-Devices-Instead-of-L2TP
  • emika56
    emika56 Posts: 6
    I tried that one but it does not seem to work on Samsung device with Android 13. I found on the internet several people reporting the same problem but no one who has found a workable solution.
    it starts to "talk" but the only result is line 60 below.
    Have no problem here with Android 12 and IKEv2
    post your settings
  • emika56
    emika56 Posts: 6
    set local policy to 0.0.0.0
    Phase 2 PFS to DH2
    Phase 1 key group may need to be higher
    Encryption to AES128
    check logs if Phase 1 show done
  • emika56
    emika56 Posts: 6
    edited May 2024
    Thanks a lot for your help but doesn't work.
    I adjusted config per your recommendation. But with DH14, DH19 and DH20 gateway gets disconnected. Other values return proposal mismatch.
    try a simple Pre-shared key
    on phone is IPsec identifier 0.0.0.0
  • emika56
    emika56 Posts: 6
    Tried both already to no avail.
    So your phone is by 4G/5G to your USG60?
    keep trying till you see Phase 1 done
  • mMontana
    mMontana Posts: 1,425  Guru Member
    Zyxel Certified Network Administrator - Switch 50 Answers 1000 Comments Friend Collector
    Sorry for being picky. It's a "pure IPSec" connection or an L2TP/IPsec connection between samsun phone and USG60? (which by the way is out of support but whatever…)
