[Release Note] Zywall Series - V4.33 firmware has been released!
Zyxel Zywall Series
Release Note
January 2019
Firmware Version on below models
USG20-VPN USG20W-VPN USG110 USG210
USG40 USG40W USG60 USG60W
USG310 USG1100 USG1900
ZyWALL 110 ZyWALL 310 ZyWALL 1100
New Feature and Enhancements
For more details, please refer to the below Link.ftp://ftp.zyxel.com/USG110/firmware/USG110_4.33(AAPH.0)C0_2.pdf
Notes for the latest security gateway firmware:
We've made some changes to better serve you. Please log into your myZyxel account to obtain the latest firmware, ZLD4.33 for ZyWALL USG security gateway. Moreover, you can also online upgrade the latest firmware from cloud helper on ZyWALL Series . Don't have an account yet? Sign up.
Can you comment which weekly builds are included? Are the fixes from WK52 included?
Thx
@Wolfgang
We suggest not to mix up the wkly build and the FCS release since they have different purpose and releasing process. For more information about the fixing, you can refer to the release note
and see if this release is proper to you.
Charlie
Hi Please can you agree if fixed on 4.33 problem with Range/Subnet settings ?
(https://businessforum.zyxel.com/discussion/2071/secuextender-4-0-3-0-for-windows-failed-to-access-zywalls-lan)
Thanks for answer
Zyxel_Charlie said:
i agree that you would not mix the different firmware releases ... but i also agree with @Wolfgang
it's a bit tricky with a ITS-WK version to validate the information "what WK edition is in the final release"
So, is there a onepager in your team, where is the WK number placed and you can inform the users like "we recommend to use WK52 and do not upgrade to 4.33"
I'm running V4.32(AAKZ.0)ITS-WK52-r86652 at my USG
Regards
Christian
Hi please is fixed Range/Subnet problem in firmware 4.33 ?
@kyssling
Regarding the issue of Range/Subnet on SSL VPN,
I can confirm the solution has been included.
Charlie0 -
@Zyxel_Charlie
can you pls check the fixes on USG60W with 802.11r reenable fix ?
i've 4.33 for about 60 minutes installed and had to rollback, cause the The WLC of the USG60W has repeatedly disconnected all of the WLAN clients and dose not provided a stable connection.
The well-known bug "802.11r re-enabled after bootup" is still present in v4.33.
Therefore the question up to which WK-version are the known bugs fixed ?
After the rollback to the WK52 my USG ran well without this issues.
Thx forward and best regards
Christian
@ChristianG
Regarding to other Wifi issue,
we will release the patch firmware by the end of Feb.
Charlie0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
