NWA50AX Pro: simultaneous WPA2-PSK and WPA3-PSK on the same SSID
Hi @mMontana ,
As of now, when you configure an SSID with the security setting set to WPA3-PSK, the Transition Mode is automatically enabled and cannot be altered. This configuration allows both WPA2 and WPA3 wireless clients to connect to the SSID.
If you prefer to have only WPA3-capable clients connect to the SSID, please consult this article for guidance.
Zyxel_Judy
I can understand the underlying logic. However, without documentation readout or your explaination, I could not be sure if WPA3 setting into WebUI could allow (or not) WPA2 working at the same time.
I don't know if one more option can be setup into future versions.
WPA3 ⇒ ONLY WPA3
WPA3-mix ⇒ like current one.Fun fact: outside the "setting", at the list of securities, the "mix" part appear :-D Little inconsinstency into wording between the two configuration pages.
Also: name of profiles and SSIDs can be edited if I download config file and edit. So, why not allow name editing from WebUI?
Hi @mMontana ,
Thank you for sharing your thoughts. Regarding WPA3, we will carefully consider your suggestion. Should there be any enhancements, we will inform users in the WIRELESS release note .
Regarding the issue with being unable to edit the SSID profile name and SSID name by GUI, could you please provide a screenshot and your configuration steps? As of now, you should be able to edit both the SSID profile names and SSID names if they are created manually.
Zyxel_Judy
I'm not able to edit the name of security profile. I might be able, if I unload and edit the file, that renaming it into config file might… have the name I want.
Hi @mMontana ,
It appears that you used the Setup Wizard for your configuration. The Wizard is designed for first-time users and provides a guided setup process, which does not support the profile name changing on GUI after completion.
If you created the Security profile manually, you have the flexibility to change the profile name as shown in the screenshot.Zyxel_Judy
This explain why that's like this. However this makes not a lot of sense for me.
I use a feature realized from the producer for speedup the setting process.. I find myself restrictied in editing ad change the setup?
I mean… I use a feature that is proposed as default (yet skippable) and this reduce the features and the options (in some way) for configuring the device? It's not that helpful… and should not proposed as the first step. Only recalled if needed, or not limiting setup in any way.
Hi @mMontana ,
Thank you for your valuable feedback and suggestions.
As of now, the Wizard setup functions as previously described. Recognizing that the ability to customize profile names after the initial setup via the Wizard might be more convenient for users, we have already initiated a discussion on this topic. You can view and contribute to this idea here:
Ability to customize profile names after setup via Wizard — Zyxel Community
Thank you for using Zyxel products and service.
Zyxel_Judy
Update & edit.
Currently for compatiblity with 2017 Honeywell CK3R I had to revert WPA3+WAP2 mixed setting to WPA2-PSK Only.
- 221 Nebula Ideas
- 612 USG FLEX H Series
- 53 Wireless Ideas
- 300 Service & License
- 483 News and Release
