Routeing rules not failing correctly if interface ping is enabled
PeterUK
PeterUK Posts: 4,342 image  Guru Member
VPN300 V5.37(ABFC.2)
so this is the setup only with more rules
When without VPN300 interface ping check on VLAN443 on Zywall 110 I block from VLAN443 to VLAN443 the rules disable correctly then when I remove the block the rules come back on line.
But if I have VPN300 ping check on interface VLAN443 to no-ip.org and bounceme.net with any one responds I then block on Zywall 110 from VLAN443 to OPT to fail the check then after some time unblock it then block VLAN443 to VLAN443 the three rules do not fail all three are up and do not disable requiring the rules to be disabled/enabled to fail check after disabling interface VLAN443 ping check
  • mMontana
    mMontana Posts: 1,444 image  Guru Member
    Never see that firmware version; currently USG Flex are on 5.38, so maybe a "version definition" is now splitting? IDK.
    Yes it might be the last firmware for VPN models being EOL but the problem should happen in current models
  • WJS
    WJS Posts: 156 image  Master Member
    5 Answers First Comment Friend Collector Third Anniversary
    Can you see prob traffic sent from VPN300 or receive on zywall110 ?
    And what's your check period timeout tolerance?
    edited May 2024
    Yes I see traffic allowed then I block for testing with routing ping check and interface ping check the problem is they both can't be enabled or it causes problems for VPN300 routing ping check to not fail after you fail interface ping check then enable then you fail routing ping which should fail but the routing ping check does not fail correctly with interface ping check is enabled after you fail it once
    I have ping check as
    ping 5 seconds
    timeout 1 second
    tolerance 2
    looking at a traffic when I block Zywall 110 from VLAN443 to OPT to fail the check then after some time unblock it causes the routing ping check to fail sending ping any more
    edited May 2024
    Video of the problem you first see my fail the routing ping check by Zywall110 the reallow then enable  interface ping check then fail that by Zywall110 and reallow interface then try to fail routing ping check by Zywall110 again and will not fail
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 982 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    Hi PeterUK,
    It seems can't replicate on FLEX with 5.38. here is my steps:
    1)Set ping check on Policy route and interface with probe domain name.
    2)block any traffic on upper device, the policy route inactive by conn-check fail.
    edited May 2024
    Check my Video
    You have to fail the interface ping check first but not the routing ping check then allow interface ping check then fail routing ping check.
    It took some attempts to do it
  • Zyxel_Kevin
    Yes I did it, but can't see the issue.
    1)Without interface ping check, then block icmp
    2)Allow ping , status back.
    3)With interface ping check, Blcok "Any", Policy route set INACTIVE as expected
    4)Allow again, status back
    5)then block ping again. policy route inactivate as expected.
    edited May 2024
    The interface is external VLAN443 to which you have the interface ping to no-ip.org and bounceme.net which you will fail then allow by other firewall
    The way in which the routing ping check is not blocked when you fail interface ping check to interface of other firewall (all be it thats not how my setup works as I NAT ICMP so not from VLAN443 to Zywall) but routing ping to Zywall to other firewall should work.
    So you have interface ping check to internet IP's which you block VLAN443 to WAN which you first block to fail the allow again
    You have routing ping check to VLAN443 Zywall on other firewall which you allow when you do the above then you block which should fail the routing ping check but it don't and when this happen the routing ping check is not sending ping.
    So when it stop working you have to disable interface ping check then disable/enable routing ping check for it to start working again.
    I could let you remote in to VPN300 when this happen for you to check why routing ping is not sending out pings any more after a fail interface ping check and allow then you can disable interface ping check disable/enable routing ping to see it sending ping.
