Does "shutdown" from the web gui really turn off the USG 110?
hoppla_schorsch
There is a button in the Web GUI > Maintenance > Shutdown > Shutdown labeled "Shutdown". But whenever I click that button regardless of the Firmware (4.15, 4.20, 4.31, 4.32) my USG110 does not turn off. It still is running (not as loud as normally) but still running. I cannot access the Web GUI anymore. As there is no turn off switch, i have to unplug the power converter. Is this a normal behaviour or why isnt my USG110 not shutting down?
@hoppla_schorsch
If you click the shutdown button, the all system processes will be stopped. Therefore, it does not mean "turn off the power."
Charlie5
@hoppla_schorsch
Charlie5 -
Dear Charlie
Thank you for you response. In fact, I've checked only the 300er manual. Have now downloaded the 110er manual and voilà!
- 588 USG FLEX H Series
- 477 News and Release
