Local network -> IPSec Tunnel -> L2TP Tunnel routing
Good day!
The model of the problematic router is ZyWALL USG 300
There was a need to create such a chain.
The diagram shows the problem based on the logs
I tried to solve it in the following ways:
- Specify the Policy Route with the following setting:
Incoming: any
Source addr: 192.168.5.0/24
Dest addr: 192.168.127.0
Next-Hop: IPSec Tunnel
- Add a firewall rule:
To: IPSec_VPN
Dest addr: 192.168.127.0/24
Service: any
Access: allow
Neither helped, only the enabled log in the dynamic route began to write when trying to ping 192.168.127.254 or the gateway in the 127 subnet: ICMP packets dropped. No rule found
I understand that traffic does not go beyond the gateway (192.168.5.200) and stops there
Question 1: What does zyxel mean by rules?
Question 2: How to solve the problem?
Your diagram looks incorrect in places could you redo?
would the routing rule
be a /24
is there more then one gateway in 192.168.5.0/24 ?
this site to site? what are the local and remote policy?
192.168.5.0 is local. 192.168.127.0 is remote. 192.168.110.0 - intermediate, where the main equipment is located. In 5.0, one gateway is 192.168.5.200. it is connected site to site with 192.168.110.0. in 110.0 there is a router connected via l2tp with 127.0. this router must be used as a gateway when accessing 127.0 from 5.0
Your diagram is not clear where the USG are Its a bit of a art to interpreting ones diagram
do you see ICMP on 192.168.127.254 by Wireshark?
do you have 192.168.127.0/24 on both USG?
I have 127 policy on both USG. I have corrected the diagram, I hope it will be clearer
Still some things unclear
PC is 192.168.5.10 but what gateway does it use and USG300 is to that gateway?
Are the Mikrotic routers or switches? guessing green is routers blue is switch?
is the routing rule top of the list?
on the USG100 can you ping 192.168.127.254 ?
- 237 Nebula Ideas
- 6.8K Security
- 740 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
