Certificate on the firewall
AdminSys
The certificate has expired on the firewall and I cannot access the interface. Can I replace the certificate with another solution?
The default certificate will always be expired in edge on that page you click advanced Continue to IP (unsafe) that loads to FLEX you can add a DDNS certificate if you want
Hi @AdminSys,
You can enter a CLI command to regenerate the certificate to prevent it from expiring or being destroyed.
Router> debug _ca regenerate
- 222 Nebula Ideas
- 616 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
