SSL VPN User limit
we're using a SSL VPN Connection on our Zywall 110 to give co-workers access to the office. After adding more than 16 users I got the following message:
Is this a general limit or a licence limit? What can I do if I need to give more than 16 users the possibility to access the VPN connection?
Error Message
Over 16 users limitation. You cannot add more than 16. |
To overwrite the limitation. Here a solution.
Add all the users into a user group.
Then select the user group in the SSL VPN policy.
6
6 -
Thanks for the advice. Exactly what I needed :-)0
- 3K Nebula
- 232 Nebula Ideas
- 6.7K Security
- 683 USG FLEX H Series
- 362 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 309 Service & License
- 504 News and Release
- 96 Security Advisories
- 5.1K FAQ
- 89 About Community
- 111 Security Highlight
