SSL VPN User limit
triJRO
triJRO Posts: 10 image  Freshman Member
edited April 2021 in Security
we're using a SSL VPN Connection on our Zywall 110 to give co-workers access to the office. After adding more than 16 users I got the following message:
Error Message
Over 16 users limitation. You cannot add more than 16.
Is this a general limit or a licence limit? What can I do if I need to give more than 16 users the possibility to access the VPN connection?
  • triJRO
    Thanks for the advice. Exactly what I needed :-)
