Add an NWA50AX access point to existing NWA3560-N setup
Jeroen2
Jeroen2 Posts: 2
edited May 2024 in Wireless
Dear all,
I have an existing setup with 5 NWA-3560-N access point, can I add and manage a NWA50AX from the same system?
Or do I end up with 2 independent configurations?
Thanks for your insights here..
Jeroen
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,615 image  Zyxel Employee
    Hi @Jeroen2,
    Thanks for the information. Since the NWA3560-N uses an old system, it cannot control new access points like NWA50AX. Additionally, NWA50AX only has standalone mode and cloud management mode. So, you need to configure NWA50AX independently.
    Zyxel Melen
  • Zyxel_Melen
    Hi @Jeroen2,
    Since NWA3560-N is an old model, the web GUI and wireless functions have some differences from the NWA50AX. May I know what you mean by the same system? Were you using a controller for configuration?
    Zyxel Melen
  • Jeroen2
    Jeroen2 Posts: 2
    edited May 2024
    Thanks for your response.
    Currently I am using a "Master" NWA3560-N to configure 5 other access points, I would like to replace one or two of the older accesspoints with a newer NWA50AX.
    Ideally I would like to keep the old master to configure / deploy my configuration to 1 or 2 new accesspoints.
    So can a NWA3560-N configure the newer devices as well? To avoid changing all the accesspoints at the same time. Hope it is clear.
  • Zyxel_Melen
    Hi @Jeroen2,
    Zyxel Melen
