IPSEC VPN encryptions, authentication and Diffie-Hellman groups - a poll
QuiteSmart
in Security
Hello community,
this post if for anyone who uses to configure IPSEC VPNs (both L2TP both pure):
which encryption/authentication and DH groups do you use on each phase?
Have you ever performed speed test with different values?
Which is the minimum encryption that you consider safe?
Which is the minimum authentication that you consider safe?
Which is the minimum DH group?
There's a perfect wizard that automatically generates the L2TP VPN configuration. I used it without making any additional changes, and I believe it should offer the best compatibility across different OS platforms.
Phase 1: 3DES/SHA1/DH2
Phase 2: 3DES/SHA1/None0
- 237 Nebula Ideas
- 6.8K Security
- 747 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
