DHCP SERVER AND NEW VLAN10 CONFIGURATION
Marcusghana
Dear All i need help on USG110 DHCP SERVER CONFIGURATION and CONFIGURE VLAN10 ON PORT P5 OF USG110 .
On the vlan10 should i create it first Configuration → Object → Zone to add a zone for THE VLAN 10. If so should put it an IP address befeore i go to configuration to create the VLAN10?
When i go to Configuration → Network → Interface → VLAN create the vlan10 on the ip assignment what IP address i should used?
On the DHCP SERVER can you assist me DHCP SERVER STARTING IP?
Hi @Marcusghana
You can check your port settings on the USG110.Then, create a VLAN interface. You can configure the VLAN interface's IP address, base port, VLAN tag, etc.
The DHCP settings can be found in the VLAN interface below.
- 602 USG FLEX H Series
- 481 News and Release
