VLANs FLEX 200 + XGS 1930 + HP Switch
Hello, how can i setup a 3 Vlan - VLAN1 (private) VLAN20(guest) VLAN30 (TV spot)
VLAN1 (DHCP - 192.168.232.1) - i whant to see all servers and clients
VLAN20 - This is isolated clients (DHCP 192.168.50.1) but can see PC and TV from VLAN1
VLAN30 (DHCP 192.168.100.1) - isolated TV, but can see PC and TV from VLAN1
I have zyxel switch xgs1930-52 and USG Flex 200 and Switch HPE 1820
not conected to nebula.
For example,
1)you can make lan1 as vlan1
2)Then creating VLAN20/30 set Base Port lan1 ,interface type "internal", VLAN ID , IP address also dhcp service.
By the way, I think create customize zone for respective vlan since it's better for design secure policy
3)Creating policy to restrict service as you want.
From zone: vlan20 can't go anywhere but can see PC and TV on vlan1. and so on.
4)For XGS1930 uplink port (connected to HP or Firewall),
Act as Trunk port and allow vlan tag 20 , 30 ( I assume native vlan is 1)
5)For HPE1820 uplink port (connected to XGS1930).
Again set Trunk port and allow vlan tag20, 30.
6)Use access port for other ports connected to the computer and set the proper VID.
When i add VLAN ID in my PC Ethernet Controller I get IP addresses via DHCP,
but if I do not enter the VLAN ID in my PC Ethernet Controller , I do not receive IP addresses
why?
VLAN 20
VLAN 1
VLAN Trunk
IP Status Detail
The ports connected to PC do not need Tagging (Trunk) .
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
