Add an NWA50AX access point to existing NWA3560-N setup
Hi @Jeroen2,
Thanks for the information. Since the NWA3560-N uses an old system, it cannot control new access points like NWA50AX. Additionally, NWA50AX only has standalone mode and cloud management mode. So, you need to configure NWA50AX independently.
Zyxel Melen0
Hi @Jeroen2,
Since NWA3560-N is an old model, the web GUI and wireless functions have some differences from the NWA50AX. May I know what you mean by the same system? Were you using a controller for configuration?
Zyxel Melen0 -
Thanks for your response.
Currently I am using a "Master" NWA3560-N to configure 5 other access points, I would like to replace one or two of the older accesspoints with a newer NWA50AX.
Ideally I would like to keep the old master to configure / deploy my configuration to 1 or 2 new accesspoints.
So can a NWA3560-N configure the newer devices as well? To avoid changing all the accesspoints at the same time. Hope it is clear.
Hi @Jeroen2,
Zyxel Melen0
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
