USGFlex200 Enable IP Blocking For External DB alert but don't block !
In our USGFlex200 with Gold Security Pack, we use an "External IP Block List".
Logs alert us about "Malicious Connection" based on "Ip Reputation" but don't block connections !!! (Access Forwarded).
What is wrong ?
Firmware version is V5.37(ABUI.2).
Thanks for help
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 922  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    Hi @Daniel64 ,
    Gretting Forum, There are bug fix about External DB . Could you upgrade your Firewall ?
    If the issue persist, Please share your Remote GUI for us.
    Thank you
  • Zyxel_Kevin
    Hi @Daniel64 ,
    Thanks your information. This is wrong note message which means the IP are blocked actually.
    We will fix the issue in next FCS/weekly.
    Thank you
  • Daniel64
    Daniel64 Posts: 2
    Another little problem (i Suppose) : When the USG device don't find the "External Block List" (by Http ou Https) it says that the Signature List is 0 and not the size before trying to update the list !
    Does it keep the previous list ?
  • Zyxel_Kevin
    Hi @Daniel64,
    Signature list should keep previous version even if update server is unavailble.
    We will have fix plan, I will update the exact ETA.
    Thank you
  • Zyxel_Kevin
    Hi @Daniel64 ,
    Thank your feedback, We will have patch in next FCS.
    Kevin
