USG Flex 200 full connect to SSL VPN with Mac iOS but dont work with Windows 11
MassimilianoDelta
MassimilianoDelta Posts: 28
image  Freshman Member
I've a problem with Windows SSL VPN connect to USG Flex 200.
I can to connect SSL VPN with Mac iOS but cannot to work with Windows 10 or 11.
I've a USG Flex 200 (Firmware Version V5.38(ABUI.0) / 2024-03-28 02:45:56).
When i try to connect with SecuExtender 4.0.5 can to see "ACCESS FORWARD" in USG Flex 200 Log but quickly received "secuextender is connection disconnect" message.
With Mac iOS i dont have problem. SSL VPN full work. My SecuExtender Mac Version is 1.2.1.
I wait for help.
Thanks bye,
Max
  • WJS
    WJS Posts: 156
    5 Answers First Comment Friend Collector Fourth Anniversary
    image  Master Member
    Your upper device have Port forwarding ? Ensure the SSLVPN port are the same.
    For example: Client connected "VPN server:10443" and your Firewall GUI is also 10043
  • MassimilianoDelta
    thanks, i checked vpn ssl port and are correct.
    With Mac iOS i dont have problem. I can to connect in SSL VPN.
    I've problem only with Windows.
    I've done one test of another customer that have an USG Flex 200 and all function are correctly.
    but I try to used TWO Factor authentication and now i cannot to connect in SSL VPN.
    What do you think ?
    Thanks, Max
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 988
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    image  Zyxel Employee
    Hi @MassimilianoDelta ,
    Greeting Forum, Please kindly share your config file any diaginfo by Private message.
    Kevin
  • Zyxel_Kevin
    Thank you, the issue was resovled.
    Follow up the FAQ. Thank you
