USG Flex 500H OpenVPN very slow
Installed USG Flex 500H quite standard with SSL VPN and using OpenVPN: Upload large file from device to server - about 0.5 - 1 Mb/Sec. Download about 3 - 4 Mb/Sec.
Are there any special settings to achieve available bandwidth?
  • Zyxel_Emily
    Zyxel_Emily Posts: 1,451 image  Guru Member
    Hi @JJ9231,
    Here is the official test report for your reference. You can disable security policy and all security services to check the throughput again.
    Using HTTP protocol to get 700M ZIP file from a server.
    SSL VPN (AES) throughput on USG FLEX 500H with firmware 1.20 is around 239.5 Mbps.
    (Security policy, Security services, BWM, DOS, Session control are disabled.)
  • Zyxel_Emily
    Hi @JJ9231,
  • JJ9231
    JJ9231 Posts: 2
    Hi Zyxel_Emily, thank you.
    PeterUK Posts: 4,129 image  Guru Member
    edited May 2024
    my Flex 200H OpenVPN is also slow can't hit past even 30Mb on a LAN test
    disable policy control goes upto 70Mb
