USG 110 to USG Flex 200
wth84
wth84 Posts: 1
Good evening everyone
Recently I had to replace a USG 110 and chose the USG Flex 200.
According to the USG Configuration Converter, you can only convert the USG 110 to the Flex 500 and not to the Flex 200. But the USG Flex 500 would be overkill for 2 people.
Is there a way to convert my USG 110 configuration for the USG Flex 200?
  • electsystech
    electsystech Posts: 60 image  Ally Member
    First Answer First Comment Friend Collector Sixth Anniversary
    No, you'll have to build it from scratch. If it's a more complex config, download the backup startup-config from the 110 and open it and you can use the CLI in the new router and copy and paste sections from the config file, eg address objects to the new router.
