Content filter on ATP800 not working
2»
  • YanShadowGT
    YanShadowGT Posts: 14  Freshman Member
    Hello @electsystech,
    For those who have an AD with many machines and need to combat the important problem that Zyxel has with the content filter, you can use this policy, this helps mitigate the problem as long as Google does not remove it since in the forums it says that it will be a policy of temporarily.
    I hope it helps you.
  • Omnia
    Omnia Posts: 53  Ally Member
    edited April 2024
  • electsystech
    electsystech Posts: 48  Freshman Member
    First Answer First Comment Friend Collector Fifth Anniversary
    Any news on when a firmware update will be available?
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 898  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    Hi ,
    We will release the fix Firmware on 5/17.
    Thank you for your concern.
  • electsystech
    I don't see the new firmware upgrade option show up in the router yet. Is there a place to manually download it?
  • Zyxel_Kevin
    Hi ,
    Please kindly find the weekly firmeware in following link . We will merge the fix in next Official version
    Thank you
  • Triess1980
    Triess1980 Posts: 1
    Thanks everyone for answers.
  • jonatan
    jonatan Posts: 191  Master Member
    @Zyxel_Kevin
    What about SSL Inspection? She still does not work Kyber. The latest weekly firmware does not fix this problem.
  • Zyxel_Kevin
    Hi @jonatan ,
    This fix only for Content Filter.
    Please kindly send your model for me. I will prepare another firmware for it.
    Thank you
  • jonatan
    @Zyxel_Kevin
    We use the following models:
    FLEX100,
    ATP100,
    ATP200,
    FLEX700,
    ATP700
