USGFlex200 Enable IP Blocking For External DB alert but don't block !
Hi @Daniel64 ,
Gretting Forum, There are bug fix about External DB . Could you upgrade your Firewall ?
If the issue persist, Please share your Remote GUI for us.
Thank you
Hi @Daniel64 ,
Thanks your information. This is wrong note message which means the IP are blocked actually.
We will fix the issue in next FCS/weekly.
Thank you
Another little problem (i Suppose) : When the USG device don't find the "External Block List" (by Http ou Https) it says that the Signature List is 0 and not the size before trying to update the list !
Does it keep the previous list ?
Hi @Daniel64,
Signature list should keep previous version even if update server is unavailble.
We will have fix plan, I will update the exact ETA.
Thank you
- 432 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 115 Nebula Status and Incidents
- 6K Security
- 388 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 43 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
