USG FLEX 500 Exclude equipment from planning
Damien_SBM
Damien_SBM Posts: 7  Freshman Member
I'm working with a USG flex 500 and i create a planification to shutdown internet connection. It works well but now, i need to exclude to equipment and i don't know where is the exclusion on the schedule.
Does anybody knows how to exclude two equipment or IP adresse ?
Thanks for your answers.
  • WJS
    WJS Posts: 156  Master Member
    5 Answers First Comment Friend Collector Third Anniversary
    How did you do "planification to shutdown internet connection",
    you mean you already implemented on FLEX500 ?
  • Damien_SBM
    On the panel configuration / Object / Schedule
  • WJS
    create another policy with higher priority. You wanna exclude IP1 For example:
    Rule1 : IP1 allow any
    Rule2: IP1's subnet allow any with scheduled.
  • JoeyErmias
    JoeyErmias Posts: 1  Freshman Member
    edited November 2024
    Does anyone know how to configure the USG Flex 500 to exclude certain IP addresses or equipment from the internet block while keeping the schedule in place for everything else?
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,526  Zyxel Employee
    Hi @JoeyErmias
    Could you share more details about your purpose? Not sure if you want to block inbound access or outbound access.
    Zyxel Melen
