USG20-VPN Console cable pinout
I own a USG20-VPN firewall, and I want to connect its serial port to my Moxa device (out-of-band network).
The issue is that Moxa rj45 pinout is not the same as let's say Cisco's, or other vendors, which means that I always have to build my own serial cables, and that I cannot use the one that shipped with my Zyxel device (also, it is rj45 to DB9, instead of the rj45 to rj45 that I will need).
I have looked for some documentation on Zyxel's console cable pinout but I did not find anything I could use.
Would you be so kind as to provide me with some docs, schematics or anything?
Thank you so much for your help.
Kind regards,
M
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,368 image  Zyxel Employee
    100 Answers 500 Comments Friend Collector Fifth Anniversary
    edited May 2024 Answer ✓
    Hello @millisent41
    Welcome to the Zyxel community. Please prepare two console cables: one is DB9 to RJ45, which connects to the USG20-VPN, and the other is RS232 to USB, which connects to the PC's USB port, for console usage, as shown below :
    Please refer to the console below information :
    It's the console serial port setting in Tera Term.
    Speed : 115200 bps
    Data Bits : 8
  • Zyxel_Jeff
    Hello @millisent41
    Speed : 115200 bps
    Data Bits : 8
