New added NAT rule don't work till you reboot USG FLEX 200H
PeterUK
edited April 2024 in USG FLEX H Series
USG FLEX 200H V1.20(ABWV.0)
Found this problem when trying to redone ports for Input Director by a gateway-less setup each NAT rule needed a reboot of the FLEX for it to work.
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,368 image  Zyxel Employee
    100 Answers 500 Comments Friend Collector Fifth Anniversary
    Hi @PeterUK
    Thank you for reporting this case to us. Please allow us to reproduce the issue and investigate it further. Thank you.
  • ZdenekB
    ZdenekB Posts: 10 image  Freshman Member
    First Comment Seventh Anniversary
    I have the same problem on the FLEX 500H - the new NAT rules do not work until I reboot the device
  • Zyxel_Jeff
    Hi @ZdenekB
    May we know which firmware version you are currently using? If this issue recurs, could you please assist us by collecting the diag-info log (Maintenance > Diagnostics > Diagnostics > Click 'Collect Now') at that time. Thanks.
