NXC2500 firmware update
IT_SVY
IT_SVY Posts: 2
edited May 2024 in Wireless
Hello team,
I was wondering if you can help me locate the updae file for my Zyxel device?
Also, is it Okay to upgrade from V5.40 to the latest V6.10?
In my WebUI, I can only upgrade to either the same V5.40 or a list of old and similar versions, should i choose one and follow the upgrade path maybe?
Please do let us know.
Thank you so much in advance.
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317  Zyxel Employee
    Hi @IT_SVY ,
    If the NXC2500's current firmware is version V5.40, you need to upgrade to version 6.00P6 first, and then upgrade to version 6.10P2.
    Zyxel_Judy
  • Zyxel_Judy
    Hi @IT_SVY ,
    Zyxel_Judy
