GS1920v2-24HP Secure Syslog
Nmes
Nmes Posts: 3
Hi!
I'm trying to understand how "Secure Syslog Messages" work.
If I understand correctly. If I set up syslog (web insterface SYSTEM —> Syslog Setup) and add syslogserver with UDP port 514 it's not "Secure".
Is there any other way to send "Secure" syslog messages with GS1920v2-24HP?
Kind Regards
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317 image  Guru Member
    Hi @Nmes ,
    At this time, the Syslog feature only supports UDP. We understand that a more "secure" Syslog option could be beneficial for users, so we will evaluate this possibility.
    In the meantime, it would be helpful if you could provide more details about the scenario or location where you are deploying and need secure Syslog.
    Zyxel_Judy
    Untitled Image
