Zyxel LTE3301-plus country options in settings
PretzelMike_2049
in Home Router
I only have two country options in the settings: Other and Russia. Is this normal or should i be worried?
From Finland
Hi PretzekMike_2049,
The country options will lead to different country code in Wi-Fi's beacon frame, if it's Default then the country code is IT; if it's Russia then the country code is Russia.
Regards,
Bob
When you select a different nation, the Wi-Fi beacon frame's country code will change. For example, if you select "Default," the country code will be IT; if you select "Russia," the country code will be Russia.
basketball stars0
- 415 Beta Program
- 2.3K Nebula
- 141 Nebula Ideas
- 94 Nebula Status and Incidents
- 5.6K Security
- 218 USG FLEX H Series
- 262 Security Ideas
- 1.4K Switch
- 71 Switch Ideas
- 1K Wireless
- 39 Wireless Ideas
- 6.3K Consumer Product
- 244 Service & License
- 382 News and Release
- 81 Security Advisories
- 27 Education Center
- 8 [Campaign] Zyxel Network Detective
- 3.1K FAQ
- 71 Security Highlight
