Ability to customize profile names after setup via Wizard
In response to the requirements raised by user @mMontana , we are considering changing the spec that allows customization of profile names after the initial setup using the Wizard as the SSID profile name, Security profile name, etc.
This suggestion originated from the discussion found here: NWA50AX Pro: simultaneous WPA2-PSK and WPA3-PSK on the same SSID — Zyxel Community
If anyone likes this idea, please feel free to leave a comment or click vote at this idea post:
Zyxel_Judy
Source of this suggestion is not reducing configuration options "for good" (until a reset) if a wizard procedure is taken to end for first configuration of a device.
If anyone feels comfortable and satisfied with the proposed names for wizard setup, that's fine. However, if necessity to change the names of the security profiles arise, customer should not be bound to reset and restart the configuration from scratch.
This should apply as rule of thumb for every setup.
I tried to vote for this request, but it does not work somehow. Please consider my vote
- 217 Nebula Ideas
- 583 USG FLEX H Series
- 297 Service & License
- 476 News and Release
