Email with attachments >5MB blocked by ZyWall USG 20
We've been experiencing an issue with our USG20.
Emails with attachments bigger than around 5MB cannot be sent from devices in the LAN.
Anti-Spam is disabled and was never used. Firmware is updated to the latest revision available.
Does someone have any clue on why this is happening or what we can tweak to fix the issue.
Removing the Zywall and connecting to the gateway directly with the PC fixes the issue. It's not a client config problem or a mail server problem.
@edo42
Regarding to this case,
can you disable the firewall and check it again?
Please send me the configuration for check further. I will private message you later.
Charlie0 -
Wrote you a PM. Problem is still there.0
Only >5MB will be dropped?? What kind of specific file formats that will be dropped?0
Small attachments go through fine. Attaching a 7MB PDF file does not work for example.
It seems like the mail client starts sending the content and then the connection just times out after a minute or so.
Removing the zyxel and connecting directly results in the mail getting sent fine in the matter of a few seconds.0 -
so do smaller PDF send ok?
When sending Email is it done over SSL?
Can you put the PDF in a ZIP and see if that sends fine.
if you go to UTM profile > anti-virus and uncheck "Scan and detect EICAR test virus" does that help?
Mail is sent to an IMAP server using SSL on port 587.
Smaller files send ok, regardless of the type of file.
I don't have a UTM Profile section, seen online what you're talking about.
I only have a Anti-X section that contains ADP, Content Filter, Anti-Spam and DNS Inspection.
Every option in those sections is disabled.0 -
Sending with SMTP from another mail account works fine with any attachment size.
@edo42,
As I checked it locally, the attachment can be received without the issue.
Therefore, can you do packet capture during the issue occur?
I will private message you the details.
Charlie0
- 435 Beta Program
- 176 Nebula Ideas
- 425 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
