FLEX50AX to FLEX100 VPN Tunnel Traffic Not Working
NSIT
NSIT Posts: 20 image  Freshman Member
First Comment Sixth Anniversary
I have several FLEX50AX VPNs to Head Office FLEX100, all working well with Quick VPN Setup, no additional Policy Routes but the last one i installed work 1 way, tunnel is up but can only ping from FLEX100 to FLEX50AX not the other way around, looks like a missing policy but don't understand how come i did not need to add one with others..
Thank you,
    PeterUK Posts: 4,268 image  Guru Member
    each end has no same subnet in use?
  • NSIT
    this issue was cause due to WiFi not pointing to Lan1 by default..issue resolved. thanks
