USG FLEH 100H SSL VPN doesn't work
Hello everyone,
I need your help, please.
I've got a big problem. I've set up an SSL VPN. I did everything as it should be. The configuration is fine, but when I try to connect from the client machine using the OpenVPN Connect client, I always get the same message: connection timeout.
So, I have no idea what to do next. I just spent so much time finding the solution.
Thank you in advance.
Greg
    PeterUK Posts: 3,983  Guru Member
    Try using a DNS name in SSL VPN settings as the interface put the IP of the interface in config that might be wrong
  • gregwl
    gregwl Posts: 4
    Hi Peter,
    Do you mean this one, I tried I put somethink like www.domainname.com and stil no connection.
    edited May 2024
    Does WAN1 have a WAN IP or is FLEX behind another NAT router?
    DNS name need to point to your WAN IP like a DDNS
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 958  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    Hi @gregwl,
    Please kindly check you have allowed port 10443 on Secure-policy if the message is connection timeout.
    And did you have any logs regarding the attempted ?
    Thank you
  • gregwl
    gregwl Posts: 4
    PeterUK,
    Yes WAN1 have WAN STATIC IP, no additional router, DNS is fine, pointing to my WAN IP.
    I tried everything.
    Although i downloaded from firewall ovpn profile and import in the openvpn connect still no connection.
    can you do a port scan to 10443 ?
    https://www.grc.com/x/ne.dll?bh0bkyd2
  • gregwl
    gregwl Posts: 4
    Hi Kevin,
    Which one exactly do you mean? Do I need to add an extra policy, or should I edit one of the existing secure policies? I tried allowing port 10443 on a secure policy, but I couldn't find the right one where I can allow port 10443.
    You have to make service for port 10443 then its
    from WAN
    to Zywall
    service TCP10443 you make
  • Zyxel_Kevin
    Hi @gregwl ,
    If you already have allowed rule , may we have remote session to check issue ?
    I send you avaiallbe time by Private message.
    Thank you
