How to IKEv2 VPN with Linux Mint using Pre-Shared Key
PeterUK
PeterUK Posts: 4,454 image  Guru Member
edited May 2024 in Security
Based off
https://support.zyxel.eu/hc/en-us/articles/4406386526994-VPN-Configure-IKEv1-VPN-with-Linux-StrongSwan
Linux Mint 21.3
Setup VPN Gateway on USG
IKEv2
Pre-Shared Key 4342v952hf24c43tvb65n554b3fg < make your own
In advance Local ID type DNS
dnsip11.ddns.net < use your own
Phase 1
Encryption AES256
Authentication SHA256
key group DH2
Setup VPN connection on USG
Remote Access (Server Role)
VPN gateway you made
Local policy 0.0.0.0
Enable Configuration Payload
IP address pool 192.168.140.0/24
Phase 2
Encryption AES256
PFS DH2
Note I was never able to have the VPN use a given DNS IP and so when VPN is up any DNS on other interfaces are uses down the VPN tunnel.
In Linux Mint
open a terminal
run su
apt-get install strongswan -y
In Linux Mint
open as root
file system > etc >
open ipsec.secrets
add
: PSK 4342v952hf24c43tvb65n554b3fg  < use your own
vpnclient : XAUTH "1qaz2wsx"
save
open ipsec.conf
add
conn vpn1
    rightsubnet=0.0.0.0/0
    leftid=vpnclient
    leftauth=psk
    leftauth2=xauth
    leftsourceip=%config
    leftfirewall=yes
    right=dnsip11.ddns.net < use your own
    rightauth=psk
    auto=add
    ike=aes256-sha2_256-modp1024!
    esp=aes256-sha2_256!
save
In Linux Mint
open a terminal
run su
ipsec restart
ipsec up vpn1
  • MJStar
    MJStar Posts: 37 image  Freshman Member
    First Answer First Comment Friend Collector Fourth Anniversary
    It looks awesome😎. Thanks for sharing.
