Port grouping USG FLEX500H
here I am again.
I need to group p2 (assigned to mail LAN network lan1) and p4 (connected to an Access Point) but it doesn't allow me to do that.
With old USG40 I could easily choose port role for any of the physical ports but cannot figure out how to do that with this new 500H. When I try to add p4 to the interface properties automatically p2 is unchecked. So as it is the Access Point connected to p4 cannot be connected to lan1. But if I try to group for example p3 and p5 it works.
Is this normal?
Kari
Hi @kaika313 ,
Greeting Forum, This is current limitiation:
P1 and P2 of the FLEX 500H cannot perfom Port Group with other ports.
Please find the firmware Release Note
https://download.zyxel.com/USG_FLEX_500H/firmware/USG%20FLEX%20500H_1.20(ABZH.1)C0_2.pdf
Thank you
The problem might be you can't group non-POE with POE?
are all references removed to add it in a group?
I've disabled Poe because right now is not a necessity and it doesn't work. But if I try to group for example p2 and p7 (or any other unused port) it does the same. As per references p4 has no References, only lan1 (p2) has:
Your can't group different port speeds
are you able to group P3 and P4?
Even if I change both ports to 1Gb speed it doesn’t work. Yes, if I try to group P3 and P4 it allows me to do that. But I need to use P2 and P4. Why it doesn’t allow me?
Hi @kaika313 ,
Thank you
Ok, now I've moved lan1 to p3 so I can group it with p4 as I need.
I was scared because as soon as I moved cables and grouped p3 and p4 both ports showed 0.0.0.0 and all network went offline but fortunately after a firewall reboot everything went back to normal and the grouped interface started working again.
Thank you for your answers
- 243 Nebula Ideas
- 6.9K Security
- 786 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 58 Wireless Ideas
- 7.3K Consumer Product
- 325 Service & License
- 528 News and Release
- 102 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
