Port forwarding over VPN with Double-NAT
I have two site, one with a USG110 and another with a USG200 with a IPSec VPN connection between them. The USG110 is behind a NAT router (a.k.a. Double-NAT). Just like in the example "VPN - Configure IPSec Site-to-Site VPN behind a NAT router"
I need access to a server in the second site using only the public IP of the first site.
How can I configure access to the server using Port forwarding over the VPN?
Thx.
    PeterUK Posts: 4,737
    image  Guru Member
    Ok update it is possible I was entering the wrong port is testing before.
    So on site A if USG has the WAN IP you need a NAT Virtual Server rule like
    incoming interface WAN 1
    external IP WAN1 interface object
    Internal IP the IP of server on site B
    and the port 80
    routing rule
    service port 80
    next hop VPN Tunnel
    your site B Tunnel
    policy control
    from WAN to VPN zone service port 80
    On site B
    routing rule
    incoming interface LAN of server
    advanced
    service port any
    Source port port 80
    next hop VPN Tunnel
    your site A Tunnel
    policy control
    from VPN zone to LAN service port 80
    image  Guru Member
    If you have a VPN tunnel and client on site one can use the tunnel to access the server
  • massimo_r
    massimo_r Posts: 5
    Sorry, I wasn't clear….
    I need to permit to a generic Internet users (I don't know this users Public IP) to access a specific port on a server in the site two behind the USG200 connected via IPSec VPN to the USG110 in the site one . The generic Internet user haven't any VPN client and can access only the site one Public IP.
    Thanks in advance for the help !
    image  Guru Member
    edited May 2024
    So the VPN tunnel does not play apart in this.
    If USG has the WAN IP on a WAN interface you just need a NAT Virtual Server rule like
    Internal IP server IP
    and the port(s)
    plus a policy control rule from WAN to LAN of the server server
  • massimo_r
    massimo_r Posts: 5
    Hi PeterUK, what you suggest is not clear to me. try xplain better my problem.
    I have two site:
    Site A (USG110) connected to internet with a double NAT, with a public IP used by external user to access a internal sever using NAT and all is working fine.
    SIte B (USG200) connected to internet and to Site A with a IPSec VPN
    I have a new server on LAN Site B that must be reached from the same external user using the Site A public IP
    In another word: I want NAT some ports of the new server in the Site B LAN for user who acceess the SIte A public IP.
    Thanks a lot for your time !
    image  Guru Member
    edited May 2024
    I see testing here you can not on site A Port forward NAT Virtual Server from the internet down a VPN tunnel to site B
    edit rechecking
    You would need to do Port forward NAT Virtual Server on site B and have user connect to site B.
    image  Guru Member
    and the port 80
    routing rule
    service port 80
    next hop VPN Tunnel
    your site B Tunnel
    policy control
    On site B
    routing rule
    advanced
    service port any
    Source port port 80
    next hop VPN Tunnel
    your site A Tunnel
    policy control
  • massimo_r
    massimo_r Posts: 5
    PeterUK, I have just one word for you: GREAT !!
    Your solution is perfect for me.
    Thanks a lot for the support.
    Best Regards. Ciao !
