[Release Note] NWA130BE - V6.75 Patch 0 firmware has been released
Zyxel Access Points Firmware Release Note
April 2024
Overview
This document provides firmware release information on Zyxel Access Points platforms, introduce new Access Points, new features and enhancements, bug fix, known issues and workarounds information for Release V6.75 Patch0 C0.
Supported Platforms
(Click Hyperlink to download the firmware directly)
Zyxel NWA130BE - V6.75(ACIL.0)C0
New Features and Enhancements
N/A
Bug Fix
N/A
Known Issue
C=Cloud mode, M=Managed, S=Standalone mode
Known Issue | C | M | S |
1. [eITS:240400399] [Symptom] In Mesh network, client connected to repeater AP, the Rate Limit feature upload rate not works. | V | - | V |
Thanks, but what is the different to 6.70?
When will MLO arrive in the firmware? As a Standard-Feature of Wifi 7 i hope it will arive early….
Hi, any news to MLO?
Hi @Chris888
The MLO technology is a default feature equipped on the WiFi 7 access point. For more detailed specifications about the WiFi 7 AP NWA130BE, please refer to its datasheet: NWA130BE_2.pdf (zyxel.com)
Kay
Hi Kay,
some words of your colleguas: Nebula Ticket #240301568
Dear Christian,Thank you for your reply.Regarding the inquiry you mentioned, it has been confirmed that the NWE130BE currently does not support MLO, but this is expected to be supported in future firmware versions. Additionally, it appears that your issue has been resolved, and we expect to close the ticket in this system. If you have any other questions, please feel free to contact us.Thank you.Best regards,Jami
So, any news reagrding MLO?
Hi @Chris888
Yes, the MLO feature is supported in the device hardware. However, since WiFi 7 clients are not very common at this stage, this function is currently not enabled. To ensure this feature is stable and performs well, we plan to conduct more rigorous testing on the device before unlocking this feature in the software. We aim to enable this feature in a future firmware release, which is expected in Q3 2024.
Stay tuned to our
for the latest updates.Kay
Hi Kay,
thanks a lot! Looking forward to Q3.
Regards
Christian
Hi, any news? Regards, Christian
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
