USG FLEH 100H SSL VPN doesn't work
Hello everyone,
I need your help, please.
I've got a big problem. I've set up an SSL VPN. I did everything as it should be. The configuration is fine, but when I try to connect from the client machine using the OpenVPN Connect client, I always get the same message: connection timeout.
So, I have no idea what to do next. I just spent so much time finding the solution.
Thank you in advance.
Greg
Try using a DNS name in SSL VPN settings as the interface put the IP of the interface in config that might be wrong
Hi Peter,
Do you mean this one, I tried I put somethink like www.domainname.com and stil no connection.
Does WAN1 have a WAN IP or is FLEX behind another NAT router?
DNS name need to point to your WAN IP like a DDNS
Hi @gregwl,
Please kindly check you have allowed port 10443 on Secure-policy if the message is connection timeout.
And did you have any logs regarding the attempted ?
Thank you
PeterUK,
Yes WAN1 have WAN STATIC IP, no additional router, DNS is fine, pointing to my WAN IP.
I tried everything.
Although i downloaded from firewall ovpn profile and import in the openvpn connect still no connection.
can you do a port scan to 10443 ?
https://www.grc.com/x/ne.dll?bh0bkyd2
Hi Kevin,
Which one exactly do you mean? Do I need to add an extra policy, or should I edit one of the existing secure policies? I tried allowing port 10443 on a secure policy, but I couldn't find the right one where I can allow port 10443.
You have to make service for port 10443 then its
from WAN
to Zywall
service TCP10443 you make
Hi @gregwl ,
If you already have allowed rule , may we have remote session to check issue ?
I send you avaiallbe time by Private message.
Thank you
- 431 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 6K Security
- 385 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
