Content filter
My device is usg210 and I add that it doesn't work with edge either
Yes, see the discussion here.
This has to do with an update for Chrome and Edge, Edge must not have updated or it wouldn't work either. There's a datecode patch for it for the newer routers. Unfortunately, Zyxel hasn't released an update for the USG series except for the Flex 50 since they are EOL. So you'll need to disable TLS hybridized kyber support in the browser or upgrade the router.
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
