How to enable both 180 Ringing & 183 Session in progress signalling?
MdTalal
MdTalal Posts: 3
edited May 2024 in Home Router
Problems with Cloud Voice - Unable to hear continuous ring in outbound calls. We have been advised "Please ensure your device ZYXEL is supported for both 180 Ringing & 183 Session In Progress signaling.
You will be experiencing the mentioned issues when either one of the above is not enabled or not supported by the device"
Regards
  • MdTalal
    MdTalal Posts: 3
    The Router Models in use are DX-3301-T0, VMG-8623-T50B
  • Liba
    Liba Posts: 232
    First Comment First Answer Fourth Anniversary
    image  Master Member
    These two routers seems to support 180 Ringing and 183 Session after I tried google search. I think you may need to ask your ISP or retailer for assistance.
  • MdTalal
    MdTalal Posts: 3
    Please find below the supplier notes
    "My suggestion would be to check for any settings in the "ZYXEL" router to enable 183/ 180 signaling which might be stated as "Early Media" in some devices as well. Also please refer to the 'ZYXEL' forums as there might be some useful information with regards to this matter."
