NWA50AX POE injector with Smart-Mesh
Hi there
I use a NWA50AX Pro in my garden, it is installed in the Zyxel Outdoor case (SKU 149000). I use the AP in Smart-Mesh mode, meaning the uplink is wireless from another Zyxel AP inside the house.
I would like to power the AP in the garden via POE from a POE-Injector.
question: Is it possible to power the AP from the POE-injector but still have the uplink wireless?
I know that some APs detect that an RJ-45 cable is plugged in and expect data coming from the cable, which is not the case in my environment.
all the best
Andrew
Hi @Wookie,
Yes, it is possible to power the AP from the POE-injector and still have the wireless uplink.
Since you have set your AP to smart mesh repeater mode, this AP will keep using the wireless signal to communicate with the root AP until you change the mode or reset it to factory default.
Zyxel Melen1
Hi @Wookie,
Zyxel Melen1
- 243 Nebula Ideas
- 6.9K Security
- 792 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 327 Service & License
- 530 News and Release
- 104 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
