Content filter on ATP800 not working
Hello @electsystech,
For those who have an AD with many machines and need to combat the important problem that Zyxel has with the content filter, you can use this policy, this helps mitigate the problem as long as Google does not remove it since in the forums it says that it will be a policy of temporarily.
I hope it helps you.
Any news on when a firmware update will be available?
Hi ,
We will release the fix Firmware on 5/17.
Thank you for your concern.
I don't see the new firmware upgrade option show up in the router yet. Is there a place to manually download it?
Hi ,
Please kindly find the weekly firmeware in following link . We will merge the fix in next Official version
Thank you
Thanks everyone for answers.
What about SSL Inspection? She still does not work Kyber. The latest weekly firmware does not fix this problem.
Hi @jonatan ,
This fix only for Content Filter.
Please kindly send your model for me. I will prepare another firmware for it.
Thank you
We use the following models: FLEX100, ATP100, ATP200, FLEX700, ATP700
- 441 Beta Program
- 293 Service & License
- 461 News and Release
