[Resolved] SSL_VPN Tunnel not Assigned to Zone/Not generating Hits
Type: USG FLEX 500H
FW: V.1.20(ABZH.1, 21.05.2024)
I created an SSL-VPN Tunnel, and was able to Set it up using the OpenVPN Client
But upon connecting i lost Internetconnection but was able to connect to the internal services
I noticed, that the Firewall Rules for the SSL_VPN werent generating any Hits.
I created an extra rule to see if i can ge the internet working if i leave the zone empty and use the VPN Subnet as a source, and it worked.
I cannot find where to change the assignment of the SSL-VPN-Tunnel to a zone. and if a check in the Zones there is an Object "ssl-tun" in the Zone, but in the Security Policy the same object is empty.
Anybody else had this experience?
Yes seeing the samewell it was the case but seem to be working for me
Strange, your Interface is Called tun0, while mine is called ssl-tun.
so is mine
With the current FIrmware 1.21(ABZH.0) the Object does not correctly show the ssl-tun and also the Firewall Rules now generate Hits.
This issue has been resolved.
- 3K Nebula
- 222 Nebula Ideas
- 618 USG FLEX H Series
- 348 Security Ideas
- 53 Wireless Ideas
- 485 News and Release
