XGS1930 - Routing trouble
Yes this is why I think L2 switch can't do this I know my L2+ NETGEAR M4100-D12G and L3 Cisco
SG350-10 can so its down to what switch you need.I have a Zyxel L2 GS2210-24 which also can't do this type of routing
I think the same ….you think the zyxel XGS2220 can do what i need?
You don't need to set static route rules on the Zyxel switch that supports VLAN routing. Our layer 3 switch, includes XGS1930, will automatically create a routing rule after you configure an IP address to your VLAN.
You may check the IPv4 routing table. Path is Menu > Management > Routing table > IPv4 Routing table. The below screenshot is my example.
So, you only need to set the static route on the firewall:
IP 192.168.33.0/24 gateway 192.168.11.2
IP 192.168.22.00/24 gateway 192.168.11.2
Zyxel Melen0 -
Thanks for the Solution!
- 241 Nebula Ideas
- 6.8K Security
- 755 USG FLEX H Series
- 380 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 321 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
