USG40 Mac based VLAN
MAC based VLAN has its uses but for you only need 802.1Q VLAN like this
But if you have a simple AP then the above will not help but Mac based VLAN is not security anything on a simple AP level before a switch with Mac based VLAN can see other devices.
So if thats the case you should get a better AP the can do SSID to tag VLAN like NWA1123-AC PRO or WAX510D
Hi Peter
I bought a NWA90AX_Pro and i have configured it for VLAN60, it seems that ist doesn't reach the USG40 with the correct VLAN.
Installation:
USG40 <-> GS1900 <-> XGS1930 <-> NWA90AX_Pro
How can i see where it stucks?
Br0 -
It works!
The Problem has been that on Switch GS1900 and XGS1930 the Ports haven't been tagged for VLAN60.0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
