NWA130BE / BE11000 Power Supply
iridium
iridium Posts: 2
what are the exact requirements to the 12V power supply for the NWA130BE AP? What are the barrel jack dimensions (I'd guess it's 5.5mm / 2.1mm again?) What's the polarity of the jack? Is there a recommended power supply to use?
Thank you!
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,043 image  Zyxel Employee
    Hi @iridium,
    Your guess is correct. The barrel jack dimensions are 5.5mm / 2.1mm. I'm sure how to describe the polarity of the jack, but I test this one and it can power on the NWA130BE.
    Hope the information on the sticker helps.
    Zyxel Melen
  • Zyxel_Melen
    Hi @iridium,
    Zyxel Melen
  • saltet
    saltet Posts: 58 image  Ally Member
    Do Zyxel sell needed power supply.
    I bought the injector 30 watt but that occupies one of the ports. Not the best solution.
    Hopefully Zyxel will answer in this thread.
  • Zyxel_Melen
    Hi @saltet,
    I will help you to check with our local support. Could you help to provide your contact information? So our local support can contact you after checking. I will send you a private message for the request, please check your private message.
    Zyxel Melen
  • iridium
    iridium Posts: 2
    Yes, this helps a lot. Thank you!
    As you can see from the sticker (the sign right of the "Efficiency Level: VI", top right of the FCC logo, it's following the more common polarity (center positive).
