Reboot and Schedule option
Zyxel_Charlie
Zyxel_Charlie Posts: 1,034  Zyxel Employee
edited July 2024 in Security Ideas
This discussion was created from comments split from: Reboot and Schedule option ?
Description:
The reboot button into the firewall. "Maintenance" -> "Schedule" and the firewall can be schedule rebooted  or on a specific date
Charlie
0 votes
Completed · Last Updated
Supported in ZLD4.60
  • DennizOlof
    DennizOlof Posts: 20  Freshman Member
    First Answer First Comment Sixth Anniversary
    Yes, thanks.
    Reboot option to prevent user error with firmware section of the firewall, and schedule function for rebooting the device after time, days etc. You can use a script but I think it would be great if you had a limited version of this in the GUI. Reboot after time, days, last day of every month etc.
    Would be nice to have. Not super important but still nice.
    Anyway the reboot option is easy to bring back.
    Thanks.
  • milo
    milo Posts: 7  Freshman Member
    edited April 2020
  • jauxi1981
    jauxi1981 Posts: 9
    hall
  • jauxi1981
    jauxi1981 Posts: 9
  • jauxi1981
    jauxi1981 Posts: 9
    Hello
    is it also possible to specify hour or hourly instead of "daily, weekly"? So in hours, every hour the firewall should reboot or every hour the DNS cache should be emptied, is that possible?
