Why gateway is not resolving the local network?
Grant
Grant Posts: 48 image  Freshman Member
First Answer First Comment Friend Collector Eighth Anniversary
  1. Tab login users - only IP Address (2024y)
  2. Tab Wireless Hostname = Empty
domain zone forwarder = local damain & servers
Why?
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,368 image  Zyxel Employee
    100 Answers 500 Comments Friend Collector Fifth Anniversary
    Hi @Grant
    Could you provide some screenshots to describe your question and problem for us? Thanks.
  • Grant
  • Zyxel_Jeff
    Hello @Grant
    Regarding your requirement, you should create an address record as a solution.
  • Grant
    Should I manually create 1000 ptr records from the primary DNS server?
  • Zyxel_Jeff
    Hi @Grant
    Could you describe your purpose to us? You provided the screenshot below with the title 'Why is the gateway not resolving the local network?' We are not sure if you encountered an A-record mapping to a private IP problem or not.
    Thanks.
