Why gateway is not resolving the local network?
Hi @Grant
Could you provide some screenshots to describe your question and problem for us? Thanks.
Hello @Grant
Regarding your requirement, you should create an address record as a solution.
Should I manually create 1000 ptr records from the primary DNS server?
Hi @Grant
Could you describe your purpose to us? You provided the screenshot below with the title 'Why is the gateway not resolving the local network?' We are not sure if you encountered an A-record mapping to a private IP problem or not.
Thanks.
- 429 Beta Program
- 2.6K Nebula
- 163 Nebula Ideas
- 6K Security
- 350 USG FLEX H Series
- 291 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 261 Service & License
- 406 News and Release
- 87 Security Advisories
- 3.8K FAQ
- 82 Security Highlight
