Allow pc to connect from outside firewall
How is your setup done? Does the WAN have like 192.168.xxx.xxx does the LAN have 192.168.xxx.xxx
Does the PC have gateway IP to other firewall?
This looks like you need to enable Use IPv4 Policy Route to Overwrite Direct Route a long with the other firewall doing static route
Hello, thanks for reply.
The setup: I have a lan with standard router with 192.168.1.xx class and foward all ports to zyxel that have some ip group. In this lan i have a firewall ( zyxel) that make antother lan 192.168.0.x.
I need that a pc with 192.168.1.x can connect to server behind the firewall with ip 192.168.0.x
what model is this zyxel firewall?
So there are some ways to do this.
1st make sure you do not have zyxel with any LAN in use or not in use with 192.168.1.xxx also your standard router with 192.168.1.xxx is /24?
so one way is to bridge and have 192.168.1.xxx with Zyxel as firewall by WAN to LAN depending on if thats what you want?
or have two subnets I then need to know if this standard router can do static routes?
or if your standard router can change its LAN gateway by DHCP to point to Zyxel as firewall to which to route back to the standard router for all devices.
or worst case to connect to the PC on on Zyxel from standard router you use the WAN IP Zyxel gets and NAT the port to the server
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
