usgflex100h WAN Ports drop nearly every Minute
Hello!
I had this issue already on that device type and tried to disable nearly every service, I tried out every Port on my Cable Modem, both WAn Ports on the Firewall, 3 Sets of Patch cables.
I set different DHCP Ranges to rule out collisions.
I tried a lot of other Setting to remidy the Problem even a downgrade of the Firmwarre but always the same Issue.
After 4 days of testing I came to the conclusion that it must be a Hardware failure and returned the Firewall, now I got a brad new Repalcement with nearly default Settings and still the same issue.
Is ist possible that the whole Productrange is faulty?
If anyone had the same Issue and knows a resolution please post it.
kr
Mike
    edited June 2024 Answer ✓
    Have you tested to the modem without the Flex?
    If you put a switch between Flex and modem do you still have a problem?
    Have you tested by knowing the IP you get and putting in static on the Flex? you can copy the MAC from a working PC and put it on the Flex WAN
  • Mike_W
    Mike_W Posts: 3
    Not exactly but I used for Years the Zyxel Zywall 310 seamlessly, which now should be replaced by the new Firewall.
    Now I put a Netgear switch between the Modem and the Flex I'll Test if that helps. (THANKS)
    I'm using the Modem normally in Bridge Mode, but the last device I tested before (usg Flex) had the same issues when I used the Modem as Router with fixed IP in the Flex.
  • Mike_W
    Mike_W Posts: 3
    I don't know exactly why, i assume Signalvoltage issue, but the Switch between modem and Firewall fixed my Problem!
    Thanks a lot, maybe I should as my Serviceprovider to send a replacement for the Modem in the near future.
